pics of Rams in use.
Islander39er
New Harbour, Newfoundland
Islander, you truly use your truck for a WIDE variety of jobs! not sure whey there is a kitchen chair sitting outside with gloves drying on it but.. it adds to the pic quite a bit, as does the tank with the large drain line!
Well, thanks!
My mom lives with me and sometimes uses the chair when she's outside.
Otherwise I do try to keep junk (or other items) sitting outside to a minimum, but it's hard to avoid completely when you're doing renos.
Which I've been doing for 10 years. Started off with a few good bones surrounded by bushes grown up to the windows. 10 years later the finish line is somewhere up ahead, but a house is never really finished.
Islander39er
Another load of soil and rocks.
The one bigger (and hard, dense) rock was too heavy to lift into the truck, so a journey uphill with the old dolly got it to it's destination. That was a workout. I'm still working on breaking apart it's big brother. That's some tough stone.
Islander39er
Another load of soil,
Then pulled up the doorstep and temporarily replaced it with the ram to build a little strip of roof and paint fascia/install soffit on the perpendicular wall. One of the easiest 12/12 roofs I've ever done.
DSC00008.JPGScreenshot_20260628_201400_Gallery.jpgScreenshot_20260628_201415_Gallery.jpg
Islander39er
Its a short bed, so however long that would be.
Right on. Factory was 6.75', but the angle of the picture looked like it may have been even shorter, which would be a custom job.
I used to see a chevy square body with a crew cab swapped on to an RCLB frame and the bed cut down. The fender pretty much tapered to a point in front of the wheel wells.
Arturo Rojas
