Plastic Air Dam ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
The Air Dam on the front what kind of pins/screw hold it in place ? Those plastic screw things ?? Thanks. One side is not flush so figure needs new screws !
pacofortacos
There are plastic push pin clips on most of it, with a normal bolt on each end - at least that is how it is on my 2016.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks, I figured it had the push pins, but did not know for sure about any nuts and bolts ! Been raining and I do not have a garage so getting under to look is out lol.. Soon as it dries up I will see if it is just the bolt or pin that is loose
HM_SanDiego
San Diego
2018 Hydro/Laser Blue CC Sport
My 2018 has 4 bolts, 6-8 plastic pins, and on the ends, one time use rivets.....
I recently replaced mine - you have to cut the end rivets off - I replaced those with a small screw and nut, because of the tightness in the corner I couldn’t get a plastic pin in there, and I chose not to reinstall the 6-8 plastic pins along the front
(there are also what I would call catch clips built onto tabs along the spoiler as well - once bolted in, and clipped in, its not going anywhere)
kad
Hudson Valley, NY
5.7L HEMI
My 2014 has rivets on each end, not bolts. Otherwise, the same, push pins.
-K
pacofortacos
LOL obviously they weren't sure over the years which way to best attach it.
One note: My 2016 is with the chrome bumper as that may make a difference.
Painted bumper air dams may be attached differently.
kad
Hudson Valley, NY
5.7L HEMI
That may be the difference, I have the painted plastic bumper.
-K
MarshRam
2014 SLT 4x4, 2012 ST
I noticed the pins were different when I swapped the chrome bumper off my SLT to a Sport bumper. But, I don't recall if it actually mattered. These are the pins if you have the sport bumper.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks I nave the chrome bumper on my SLT . I believe I have a few of those laying around :)
gville35
