Please help AlphaRex headlights
GMC7784
Canada
Hemi 5.7 v8
Hi,
I bought the luxx series headlights 5th gen for my 2020 ram 1500 classic with the converter harness.
I'm wondering how to wire the harness. That's because of the big connector. I have not this one on the truck but the two little ones for the low beam and turn signal (see the pic).
Is someone has an idea how to wire this harness properly please?
FYI, see below the converter link
Thank you very much for your help.
20210613_095346-jpg.250494
https://alpharexusa.com/product/13-...-to-alpharex-projector-headlights-converters/
Wulf
United States
Did you try contacting alpharex directly? And did you ever find a solution to your problem?
Mopar1987
Livingston TX
Is your truck a factor projector truck? If so, that’s what that adapter is for. I put alpharex luxx 5th gen style on my truck and the adapter plugged in perfect.
hunterdan
SE PA
2019 classic
You shouldn't need the converter harness if you have what you posted. Should be a plug that plugs into your turn signal socket and another for the headlights .
geneseedennis
