Please help
donovanhedden
US
2017 dodge ram
I have a 2017 dodge ram 1500 Longhorn I want to get the exhaust done by a shop but they say they will not touch it because of back pressure
Sent from my SM-N950U using Tapatalk
D
donovanhedden
US
2017 dodge ram
Because of a back pressure....? Feels like there should be more info here.
That's what they told me and it's a shop I've been going to for years but they got a new guy and no one has gave me a exact answer
unxpctd
Minnesota
2021 PW 75A
Sounds like you need to find another exhaust guy.
The only thing I can think of is that he is claiming that there won't be enough back pressure once he replaces the Y pipe.
Putting in a new muffler or Y-Pipe can lessen pressure on the system and open it up a bit. That's not a bad thing.
Just my .02.
grizzstang
Calgary, Alberta Canada
For now just to put the right y in there not that crushed one
Many here have done it and I looked at doing it myself but in the end most seemed to feel that it really wasn't going to be a factor on a stock truck. You will have no issues if you do decide to swap it out though. I did my muffler and tailpipe about a month ago and have been very happy with that.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Probably not worth it if you not going with a better flowing muffler.
If you live in NC, I can tell you who will do it, they fabricate their own y.
They did mine.
crackerjack1957
And another thing on the back pressure why would you purposely flatten one side & not the other.
hotrod45
Home
If you look at the point where the two pipes meet (9 o'clock) on the circumference, it is evident that both of the pipes are flattened. At first glance, though, it does look like only the top one is.
AFE makes a bolt-on Y pipe,you can get it through either Nick or Matt at Moes,both are vendors on here.
crackerjack1957
Pretty sure 1 is flattened more than the other.
Saved mine in garage, will take a picture later tonight.
crackerjack1957
Looking through the cutout inside & they look the same, on the outside the one that does not look as flat at the Y crosses under the transmission & is flattened there also so yes they are pretty much equal.
NCRaineman
NC
2019 1500 Classic
Backpressure?
In other words they don't want your money. Time to find a different exhaust shop.
McBroom
Denison Tx
Hemi 6.4L
Nick @GotExhaust.com a preferred vendor here for all things exhaust related. Contact Nick he knows his **** with exhaust systems
Blue Streak Pearl off-road package
Saleen5150
