Plow Guru Needed
tynriggs
Clinton
Would anyone know if a Plow and “Mount” Setup from a 2005 Ram 1500 will Fit onto a 2006 Ram 1500 ?
Thanks
joepenguin
Should be fine, same generation trucks. What type of plow? I run a Fisher MM2 on my '03 and the only things that swap between vehicles are the pushplates and wiring harness. If you go to the Fisher plow website you can get the part numbers for your vehicle, compare the 2 years, they should be the same part numbers.
Raadz
