Dubstep Shep
- Aug 4, 2014
- 2,240
- 514
- Location
- Houston
- 2014 R/T
- 5.7L Hemi
So most people on here are probably aware of the popularity of eliminating the clutch fan on these trucks.
If you're like me, the size of the factory cowl is a bit of a nuisance, but getting rid of it leaves you with the AC fan and no cowl. That's also a nuisance IMO.
So the only solution then is replacing the factory fan with the v6 fan. But even that has a problem. The connector for the v6 fan is several inches higher than the factory fan.
You can see the gap here:
But I've come up with a plug and play solution.
As far as I know, there are only two ways to create an extender for the harness. One would be to cannabilize a harness from a truck. That's a terrible idea considering the expense.
The other way is to build a harness. This isn't possible for most people because you can't just buy the connectors.
Fortunately, I have some contacts from when I used to work in the automotive industry, and they work specifically with electronics components. I found one who got me ten of the connectors I needed to make an extension. I used the wires on my old fan and cut apart some crimp terminals to make everything fit.
Here's the final result:
And it plugged in:
So at this stage I have nine more connectors. I can sell them to you guys, but I'm trying to find the exact terminals they use so I don't have to cut apart my own. If I can do that I can include them as well, meaning all you have to do is cut off the connector on your fan with about six inches of wires, crimp on these ends, then put them in the connector and plug it all in. Not too bad.
And it plugged in:
