plugs and wires
cody mummert
Pa
just rolled 60k when do you guys do wires and plugs ?
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Plug wires? You sure you have those? 2015 right?
Joshwaa
Lake Worth, FL
I believe the plugs are rated for 100k, but I will be changing mine at 50k.
huntergreen
Marine Corps Navy Badge
I,LL change my plugs around 90000 miles or so.
MidwestJ
Illinois
‘09 here. I change mine at the 30-35k mark.
Paid the dealer the first time. No more of that chit.
Did it myself the second time. Sucked balls but saved several hunered dollars
you have coil packs not wires, and you should be good to 100k when you should likely change plugs and coil packs if it is for a 2015 hemi. It's best to buy from vendors here, as they always have the right type for the year, they are different.
Here in CA I may never need to replace coil packs, but you live in PA so I'm guessing you see snow and cold winters. Might be a good idea as they aren't that expensive to replace when plugs are needed. There is a way to test if they are bad, but I would just do it all at once and button it up for another 100k miles.
noraa73
