Polishing Chrome Plastic Hood Protector
moledodge
DAT HEMIIIIIII 5.7
Hey guys I'm looking for some help here. I have a hood protector that looks great but has visible "specks" on it no matter how much I clean it. I don't know how to polish it since it's not exactly chrome metal. Here's a pic any ideas??
https://m.imgur.com/7YnHHB6
daggertats
arden nc
2011 ram reg cab 4x4
the link doesnt work......if your talking about the chrome plastic one like i have i use car wax on it and it cleans it up great.
M
moledodge
DAT HEMIIIIIII 5.7
Link should work now
carl0
Hemi 6.1
You can try 0000 steel wool combined with a wax or sealant, though try a small spot first.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
I would definitely not use steel wool on that since it's not real chrome or metal. It's essentially a plastic coating on top of plastic.
Your best bet is going to be a clay bar. Clay bar it just as you would any painted panel on the truck and then throw some sealant or wax on it.
AustinB
Banned
San Diego, Left Coast
Hahaha! You troller, you. Steel wool is best for cleaning the inside of tinted windows, not plastic chrome.
IMO
AustinB
Banned
Clay bar, windex, alcohol.... Anything. Did you buy it new? Could someone have applied wax over the spots?
IMO
Brian_Ram
If it's above surface contaminants a clay bar will work. I would not use Windex or Alcohol though because it will remove any wax it comes in contact with. Most clay bar kits come with a lubricant that will work well. If you are not sure if its above surface put your hand in a plastic sandwich bag and lightly go over to see if you can feel it. You can also use a light polish like Meguiars Ultimate Polish. I've never had any problems with it on chromed plastic. It may be water spots in which case there are many water spot removers. When you finish with either put a couple good coats of wax and/or sealant on it.
averageguy
Belleville Mi
hemi
The pictures look like hard water spots. If that's the case, vinegar should take them off. If its bug residue I use turtle wax bug and tar remover on mine.
rduchateau2954
DO NOT STEEL WOOL PLASTIC!! Use a clay bar, then wax it afterwards. The wax will help with bug guts.
Sent from my AS985 using Tapatalk
rduchateau2954
This guy knows what's up
