Possible fuel pump relay issue?
cajunrebel82
Hey everyone, I have a 2010 ram 1500 5.7. Out off nowhere this morning truck would not start. It turns over but no start. No codes on the code reader. Looking online I'm seeing possibility of fuel pump relay. I have 2 questions.
How do i test this?
If it's bad, what are the options to repair it?
Thanks for any help.
PoMansRam
East Aurora NY
Can you hear any buzzing from the fuel tank area indicating the fuel pump is working?
I would say the FP failing is more common than the relay, but being ~12yrs/old, anything is possible.
PoMansRam
East Aurora NY
Have you tried pounding on the underside of the fuel tank a bit to see if that will jostle the fuel pump back to life?
Burla
2010 Hemi Reg Cab 4x4
You have to use cig lighter if you do it so it turns off with key.
jws123
nj
I had this issue if the relay turns out to be bad on timp board order one for $4 online i can get the link re solder it onto the board no big deal had to do it 3 yrs ago easy to do mine is still running today.
C
cajunrebel82
Thanks, get me that link for the relay if you can. I'd rather try that first before i start spending major money.
jws123
nj
I will see if i can find where i got it first confirm your fuel pump is good
jws123
nj
this link should work exact ones i ordered.
and here is how to do it think this is the vid i used but like i said confirm your pump is bad and wires to pump are good.
