It is on your Uconnect under controls. You might want to try reading the owners manual, there is a ton of useful info in there about the power boards, and quite a few otehr things for that matter.
POWER SIDE STEPS — IF EQUIPPED
The Power Side Steps will extend a step for
easier entry and exit of the vehicle.
When configured for “Auto” mode, the Power
Side Steps will deploy when any of the doors are
opened, or when the deploy setting is activated
through the touchscreen. When configured for
“Store” mode, the steps will not deploy unless
the setting is selected manually through the
Controls menu within the touchscreen.
If the vehicle speed exceeds 5 mph (8 km/h), or
if the retract setting is selected within Uconnect
Settings Ú page 258, the steps will retract.
Power Side Steps
When the Power Side Steps button is pressed on the touchscreen, the system will display the setting related to the lowering of the power side steps.
Setting Name Description
Power Side Steps
This setting will raise and lower or stow the Power Side Steps. The
available options are “Automatic” to raise and lower the Power Side Steps
and “Stow” to deactivate the Power Side Steps.
