Power mirror option
Avgas
2015 Express
3.6 Pentastar
You will need to get the window switch, window modules, and a get a dealer to flash a sales code to your truck, which is nearly impossible to do, I have only heard of 1 member accomplishing this. You can also wire the motor to a 12v switch yourself and avoid the hassle. I have some powerfold sport mirrors sitting at my desk and I plan on doing this soon.
R/T_Fire
R/T_Fire
Pleasant Grove
Hmm I may look into this more, I could wire it to the lock switch somehow I think with the alarm . Guess I need to figure out some wiring and system operations first . I am equipped with the puddle lights that aren't on the truck right now.
Ricks Ram
I wired them into my 2014 Express. I got two small momentary 6 pole micro switches. I mounted them in my driver side door panel I now have individual control over each mirror I use them almost every day they work great. Not sure about the 2011 but on the 2013 up trucks the wires you want are the blue and the yellow that are in the black plug. Since my truck was an Express the dealer could not install the LER sales code for the power fold option. The only really hard part is running the wiring through the factory wire looms into the drivers door.
Avgas
2015 Express
3.6 Pentastar
Can you post a simple wiring diagram showing how you wired these? thanks
sbarron
Wasilla, Alaska
Obviously don't forget that when you drive, your doors lock, lol
Now you've got me thinking. In case you're wondering what that smell is...
R/T_Fire
R/T_Fire
Pleasant Grove
Yeah thats why i want it on the alarm circut... but not sure if that is possible. Need to do alot more research. With these canbus systems it should be easier but its not
Sent from my SM-G920V using Tapatalk
Ricks Ram
I did a write up on it when I did it. I will post the wiring and quick instructions when I can type it all out a little later on lunch.
Ricks Ram
Ok this is a picture of the switches I used and a wiring diagram to wire them for reverse polarity. Remeber to get the 6 pole momentary switch. You can fold the mirrors in or out as much as you want individually. I ran the yellow and blue wire from the passenger side mirror to the driver's side door as well as a positive and negative wire. I ran the positive from my battery to a fuse box I installed under my drivers seat. I use it to run my seats,mirrors and illuminated sunvisors. I installed the two switches side by side hooked up to each mirror separately. As I stated the hardest part is running the wiring into the drivers door through the factory harness.
Avgas
2015 Express
3.6 Pentastar
Great info. I might just wire both mirrors to 1 swicth
R/T_Fire
R/T_Fire
Pleasant Grove
That's a pretty slick spot to put them switches, but for me I want it to be automatic somehow when I park. Don't really need it other than that desired for a little extra protection from the ******* in parking lots
No members online now.
