Power outlet on top of dash to ignition rather than battery?
HeavyG603
Free Republic
Probably a lost cause but does anyone know if there is a way to switch the cigar 12v outlet on the top of the dash on the 2020 3500 to ignition rather than battery? I have my radar detector and dash cam plugged in there and I constantly forget they are on. So many configurable things in here I figured this must be too but I haven’t found it yet...
unxpctd
Minnesota
2021 PW 75A
I found a workaround without rewiring:
https://www.amazon.com/Ninth-City-C...+volt+plug+with+switch&qid=1591274233&sr=8-15
This isn't the exact one I have....but I plugged one like this into the cigarette lighter attachment/port on the back of the center console. I ran it along the center console up to under the dash.
I have a large Garmin GPS and a Dash Cam plugged into it under the dash. I have a double attachment plugged into the extension to run 2 electronic items.
When I get in my vehicle I reach back and turn the switch on. When I leave or park it...reach back and turn it off.
Just my workaround....I didn't want to do any major rewiring.
Good luck!
H
HeavyG603
Free Republic
Good luck!
Thanks bud. I’m holding out hope Ram Engineering planned for this.....
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Find the fuse that controls it. 54 on a MY 19 1500 DT. The fuse has (2) positions: Battery/Ignition. U have to move the fuse to the ignition slot. May be in box under hood or inside truck.
H
HeavyG603
Free Republic
Thanks for the tip ! I’ll do that and report back.
H
HeavyG603
Free Republic
So under the hood on mine it is marked F90/91 it’s a 3 prong micro fuse (plow installers tapped it). Not clear to me how I move it between as there is no other slot that it would fit.b3e1dd8b9bcb670e80dfbf7b02ef7f58.jpg
John Jensen
San Diego County
Ecodiesel
90 & 91 share the middle slot
However, on my 2020 90/91 change the USB port #5 serving the rear seats. Has nothing to do with the cigar lighter.
H
HeavyG603
Free Republic
It definitely does on mine. It’s dead if I pull it. I’m wondering if I stick a micro in either side if that’s the select ?
John Jensen
San Diego County
Ecodiesel
I would assume so. What would you do with the wire using the 3 prong?
I've never seen a 3 prong fuse before. I can't advise you as I have no idea why plow installers would use 90/91 and that type of fuse.
That's a new one to me :mad:
H
HeavyG603
Free Republic
Well that was it, took out the three blade and put the two blade micro 2 one in and that was the trick. I’ll be calling them Monday but I’m assuming it was for the controller. Why a 3 blade 15amp when the factory specifically asked for a 20 is what baffles me still. Thanks for everyone’s help!
John Jensen
San Diego County
Ecodiesel
That's all good news. Yep, my 2016 also shows it as a 20amp. I'm sure so it can handle anything you would plug into it.
turkeybird56
Central Texas
YES, 2 bladed, in 1 way ignition, forward (other way) battery...
That is 1st time I have seen a 3 bladed fuse like that also
ADDED: U prob gonna have to get power to the controller on yer plow I guess. With that 3 prong in there, it was like jumping circuit on both sides. But I cannot say which side to plug in, U gonna have to use a tester and determine all that and figure out which position the 2 blade for Battery/or Ignition, but from how I am reading yer post, I think U have. Now U gotta get power to yer controller.
whetrick1
On my 2019 the lighter plug goes off when you turn the ignition off. Because I've had my tom-tom plugged into it and it'll go off when I turn the ignition off
H
HeavyG603
Free Republic
Should be the default right ? Well not on mine. Through some assistance here and experimenting I got it switched though.
KoboldTaco
Los Angeles
Cummins 6.7L
This thread was dead for a while but did the trick for me yesterday. In my 2022 2500, there is not a 3 position fuse, but a three position 20A socket with a fuse that I moved to the opposite side and it now works on ignition.
DubC
Iowa
Can confirm that it's the 20amp fuse in 54a/b for the 1500 models. Default it's in left/middle. use the fuse puller from the engine box (or whatever you'd like) and swap it to middle/right. I cannot verify the lower plug in the cubby, but the top-of-dash plug is now ignition based and not always on. this is how it should have been from factory in my opinion. at least there's an option i guess.
it's different for the 2500/3500.
TexHD
Abilene
Ram 2500 Hemi 6.4
Great thread. Thought I was going to have to go to the dealership and have it programmed or something. My 2024 2500, switched the 90/91 20 amp fuse and it works perfectly. Thanks.
