Power step haunted
RJR49
Marine Corps
2022 1500 Limited. The drivers side power step extends when I open the door then upruptly retracts. Occasionally rarely it stays out but the next time it once again plays hide and seek. Any ideas that help would be appreciated
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Any chance it's slightly binding and retracting like it's supposed to. My amp steps will retract if they hit something, and I'm guessing your factory ones do the same.
JayLeonard
6.7 L Cummins
Might be a harness connector somewhere that is loose or has moisture in it.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
As stated above, check for debris or obstructions... including anywhere the step moves "through", side of truck (both sides), hinges etc.
Might just need some dry lube on the moving parts.
Jim M
Hemi 5.7 e-torque
We had the same problem on our 2020 Limited. White lithium grease solved it. Occasionally a buildup of ice and slush would force the step to retract or freeze it down, but friction seems to be the biggest issue.
