Power Wagon Tires - Post Up Your Info
Tinman454
Saskatchewan
AEV pro cal snap was a easy install and worked very well. If you are looking for something to reprogram tire size it works well. Hardest part is getting up under the dash, well it is for a 240lb 52 year old man lol.
retired
montana
Just a rumor but I heard if you pop the panel that has the headlight switch you can just reach in and plug the harness in easier...:)
Xyleff
California
Anyone here running 18x9 +12mm on 35’s ? Wanting to know if it needs any trimming or if it’ll rub any. Don’t wanna pass up on a good deal, but also don’t want any rub or trimming either.
thkbaron
Minnesota
They won't rub. I'm not running that particularly but I run a 1 offset with 35s and they don't and I ran stock with 35's and they didn't. so in between you should be fine. On a side Note I'll be running 35 12.5 18 Toyo R/T's on the 22 and 18 inch method 305's with I believe an 18 offset.
Katy, TX
Brand: BFG AT KO2
Size: 35x12.5 R17, E Rated
rubbing: None
MPG: 14-15
Off road performance: Excellent, except in mud
Wet performance: OK, but not great
Highway comfort: Quiet, much better than stock, but they have to be rotated and balanced every 4k miles or they start to vibrate
Snow/Ice: Unknown
Lift or level Required: None
Tread life: Unknown yet
PSI: 50 front, 45 rear
Xyleff
California
Were you on stock suspension with the 1 offset?
thkbaron
Minnesota
I've done both. But the other than stock suspension I ran was only 1/2 inch over stock Thuren. I'm on stock right now with the 35's and +1 offset.
Xyleff
California
Thanks, appreciate the response! Getting me those +12.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
i ordered a set of 5 ridge grapplers, 35/12.5/17's for towing my travel trailer.now i'm trying to decide on wheels.i have the stock duracraps for winter use and a set of 35/12.5/20's general grabbers for summer. 3 sets should do it.
olyelr
Kewadin MI
Ummmm. And why cant the general grabbers be used to pull a travel trailer?
aces2splash
Central Texas
V8
What your avg. MPG with those 37's? I have the 35's of the same tire. I'm rolling at 9.8 in town 10.5 HWY.
thkbaron
Minnesota
Thanks. Still trying to get used to the Methods. They are kind of boring compared to my Fuel Blitz DDT's. I jsut didn't think the blitz's in the 18s with the positive offset would have looked as nice. Less dished.
ameer73
