Power window problems
Xpflive
So i just got my 09 recently but i was a meathead who forgot to close my window before a few rainy days now the power from the drivers door front windowd. Mirror tilt and lock buttons dont respond. However rear window buttons work fine. Did i water damage the button panel and need a replacement?
shaftman_05
Southern Michigan
That would be my guess. May be able to remove it and dry it out if you haven't kept trying to use it
X
Xpflive
Yeah at first it worked fine. Turned off truck. Fired up again then the problem happened. Half hour later it functioned again fine. Then it went back and crapped out again. But ill try drying it out see if that changes. I cant see a new part being too much money off a wrecker
