sredbeard
I have a 013 2500, it has a express down but not express up power window switch on the drivers control. do they make one and if so can someone please give the part number or tell me where I can get one, thanks
I was under the impression that all trims came with auto up/down for both the driver and passenger window, regardless of trim. Most likely a switch issue. Being a 2013, you should take it in under warranty...
what is a Directed 530T ?
Not all models are equipped with the option, if the switch says auto on it is, if not you need to change out the switch and add the flash or program the BCM.
Rock auto has the switches for not too much money. just make sure they say auto on them.
My R/T only does auto down, not up. not a option on alot of RCSB for some reason
FWIW, My 11, 12, and 13 all had auto up down for both front windows and none said auto on them...
