Corey Wickham
New member and just bought a 2011 quad cab sport that has a pro comp 6in lift on it. Someone replaced the upper control arms before I purchased the truck but has an alignment issue. It has negative camber on the top causing the inside of tires to wear rapidly and also gives it bad bump steer. Had it on the alignment rack and theres no more adjusting that can be done. Emailed pro comp to see if there is different upper arms but have not heard back from them. Wondering if anyone has any ideas, other than a different lift, that I could do. Thanks in advance.
