Problem with remote start
Hemimania
Central NJ
Hi all. My remote start only works when it wants to on my 2014 Ram. I will keep pressing it over and over and then it starts (sometimes i press the lock button then press the x2 button again and it starts) . The lock, unlock and panic, on the remotes, all work fine. I tried both remotes and it's the same. Tried putting in new batteries and it's the same. Is there a way to reset it somehow?
Thanks,
Tonino
jws123
nj
your remote start wont work if your vehicle is low on gas or has codes stored in the system. Is it a factory remote start or after market?
Rlaf75
East Hartford CT
2021 Bighorn
you can try to disconnect tbe trucks battery for a about an hour then see if it starts working. That will give the trucks systems a "reset".
RamDiver
Marlborough, Ontario Canada
2021 DS
What kinda codes and how would I know?
You could try visiting an auto parts store and have them test for any existing codes.
They will test at no cost. The problem is, unless a DTC is captured as a historical, it may not be present when you test.
Any DTC will disable the remote start.
Sometimes they come and go, in which case it might be worth borrowing or buying your own scanner. Then, you can test while it won't remote start.
Start with a parts store DTC check and you might get lucky. :cool:
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Wouldn't it have to be a CEL to disable remote start, or will any DTC do it?
Hemimania
Hemimania
Central NJ
Had battery checked. Said it was good. Went to get gas and start it to leave, now it's giving me "Key fob not detected" while I'm sitting in the vehicle. Had to wait 30 sec to start and it started. Going to step 2 and disconnect the battery.
Tonino
Clint Millard
Langdon Alberta Canada
Thanks,
Tonino
I had the same issue with mine, lock and unlock always worked, start only worked when fib was out of case, bought a new set of fobs and good as new now.
Airforce 1
Rio Rico AZ
Thanks,
Tonino
Open fob add plastic to each of the contacts in the rubber cover should work.
ts27330
V6 3.6
Thanks,
Tonino
the "x2" button (a circular arrow with a "2x" inside) on a Ram 1500 key fob means you should press it twice within 5 seconds to initiate the remote start.
Dean2
Near Edmonton
Thanks,
Tonino
You ALWAYS have to press the remote start button twice, fairly close together, for the vehicle to start. It will never work if you just push the button once.
It will lock the doors when it remote starts. Will not remote start with a door open, or the hood open. Your owners manual has a long list of the things that must be true for remote start to work.
Hemimania
Hemimania
Central NJ
Yes, I do press the x2 twice but sometimes nothing. Might be that fob because I switched fobs and it worked (especially when i opened the fob and it was in pieces).
Hemimania
Hemimania
Central NJ
Really? Hmmm. How much did they cost if u don't mind me asking?
