problems running staggered tire sizes
jedeisurf
Glendale AZ
Hi I am currently running 305/50/20 tires with a bell tech 2/4 kit thinking of running 275/55/20 in the front because of clearance problems going to the Inez 4/6 kit, what issues can I expect doing this. Possible rotation problems?
Thanks
moregrip
Thanks
I think in your case zero issues because the rolling diameter is roughly the same for both tires.
I am running 305/50-20 rear and 285/50-20 front and also have zero issues
charonblk07
Calgary, Ab
F1-A forged 349ci
There's no issues running a staggered setup as long as you're not a 4wd. The only issue you'll run into is not being able to do a normal wheel rotation, you'll need to swap them between sides and expect to change out a pair of tires faster if you have any alignment issues or you like to do burnouts.
