Programming garage door opener
Omotose
2017 Bighorn 2500 4x4
I am having the hardest time programming my garage door openers on my new truck. Is there a secret other than what is written in the owners manual?
stimpy433
IOWA
Make sure you're using the correct procedure depending on if your opener is a rolling code (99% of newer openers) or not. Which one are you having problems with programming???
Ledawg
Indiana
2013 Big Horn
I just did mine and was a breeze. Mine has the rolling code. Did both doors with no issues.
Csanders1992
I programmed mine to my parents garage door and had to hit the button on the back of the garage door opener. My girlfriends parents was a breeze and worked with the normal procedure
gustheram
Central Florida
5.7L
Mine programmed easily enough. Button on the opener, button in the truck. I think I might have had to use the remote to get the truck to learn the signal. No secret sauce needed. It only works about half the time though.
pcschwenke
I had to unplug my garage door opener, then plug it back in, thean follow the procedures in the book. Be sure to keep it unplugged for a couple minutes. I fought with mine for nearly an hour one day. It wouldn't program. Then I read others having the same issue and the problem was solved by the unplug. Good luck.
O
Omotose
Thanks guys finally got it done. Basically read the instructions all the way through for the 3rd and it worked.
geneseedennis
