Project: Handle Like a Porsche!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
As addictive as candy......
Just give it one more inch......
OklaHemi
new age hemi
yeah the 22"s help fill in the wheel well but the 305/45 actaully made it sit a little higher.
im running 305/40 on the front now and they are 1" shorter overall. i can tell a difference.
Trupiano
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Yeah that's what I figured. When I eventually get 22's... if I do. I want them to sit how your truck sits. That's so damn gorgeous man! Im almost there =P
I think, it being a 4X4, it was a little higher than normal 2X4 trucks. Is this true? Never really compared.
Redtruck-VA
Virginia
Trup, no doubt the 2wd start out lower. My 2wd was lower than the other 2wd's when new.Strange how the trucks vary one to the other,
Trupiano
Trupiano
Registered User
6.7L CTD
Yeah no kidding. Guess that's what makes them unique. Just hard to find the perfect drop height I want. Ill have to mess around with the shackle silverbullet is sending me and the torsion bars.
srt2slow
fort dix
viper v-10
it look good....where did you get that sway bar from???
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I think he has the Hellwig! Belltech makes one too! I priced the Hellwig for $ 320 but thats up here in Canada. I Think they run $ 220- $230 down south.
srt2slow
fort dix
viper v-10
i have the 5 inch drop now and my old swaybar end links were to long so i took them out....do you know if the just sell the shorter endlinks???
Redtruck-VA
Virginia
I have found making things shorter is much easier than making things longer generally speaking. Post a picture of the link with it's deminsions.
Redtruck-VA
Virginia
If the link is straight with polyurethane bushings on both ends it is simple to make using a piece of all thread, small diameter tubing or pipe, four nuts and the bushings with washers. Determine the length you want and cut the tubing to that length. Slid the all thread into the tubing, leaving enough thread sticking out both ends to assemble the bushings. Assemble for fit, disassemble to paint, assemble and tighten, then add lock nuts or use nylon lock nuts.
southalum
