projectors to replace
rwhjr
maryland
want to get rid of the quad headlights and replace them with some TYC projector housings.....
https://www.carid.com/tyc/replaceme...MIzObmn8fF2wIVGLbICh3yJA-xEAkYAiABEgImNPD_BwE
what bulbs will work with these? will some sort of harness be necessary?
whats the best plug-n-play option for me if i get those headlights?
i want reliability as i dont want flickering issues or any problems with whatever setup i go with. reliability is an absolute must.
WhiteNBlackRam
Southern California
Yes, you will need a harness. I would get in touch with Jermey from RetroShop as he will explain everything you will need.
rwhjr
rwhjr
maryland
Gotcha
I’ve read through a few posts of people having issues even with the adapter harness
I just want to make sure I’m getting the right bulbs, harness and everything I’m going to need to have a reliable setup.
So if I get:
Retroshop harness
what bulbs do I need?
And with those three I should have a troublefree combo?
firemedic10584
Central Fl
I may be mistaken here, but I ran a set of those TYC projectors on one of my previous truck (great replica of the OEM projectors by the way) and if my memory serves me right, they used the same bulbs as the factory projectors do.
rwhjr
rwhjr
maryland
yeah my truck has the quad headlights, though
i cant just swap housings and re-use the bulb/harness setup with them can i?
chrisp2493
Always Modding
Warren, OH
392 Hemi
It’s a big harness with multiple resistors, a capacitor, control relay, ballasts, and starters. It’s a very high quality piece and they stand behind their warranty, I had my entire thing replaced for free, no questions asked when I accidentally put the relay is a position to get some water in it and corroded a terminal. I wouldn’t call that a “rip off” by any means
I Bleed Ram Trucks
JPT
NY
2015 Big Horn
Order the projector housings and take delivery. Then once in hand validate the bulbs before ordering the HID kit. I would also suggest Jeremy at RetroShop. You can order the HID kit with the required bulbs (my aftermarket projectors needed an H7, which was not an option on Jeremy's site, but after talking to him he told me what to do to get what I needed), and the halogen to projector adapters V2.
Some of these projector housings use different bulbs, so it would be better to make sure you get what you actually need.
feets
