Puddle light problem
Egor
Baltimore, MD
Anyone had there puddle lights stay on for like 15 min after key is out, what's the fix cause it burned out one of mine!
And next question how do I replace them??
outkast
i normally just lock my doors when i get out the truck and the lights go off.
jwheeler
Washington
There is a problem if you lock it and all the lights go off except the puddle lights.
E
Egor
Baltimore, MD
If I turn the truck off get out shut the doors they stay on for like 2-3 min but if I open and **** the door after that (without putting the key in) they stay on for like 15 min and it burned out the passenger side one!
How this can be kosher
MoreOvalteenPlz
Stillwater, OK
I'm guessing OP can't adjust his lights on lock/unlock settings like 13+ trucks can being that he has an 11. I've seen a thread or two on here of guys removing/replacing the puddle lights. Sounds like there is definitely a fault somewhere in the system...
BlownGP
Houston/Baton Rouge
Is this after you lock your truck?
Mine only stay on for a few minutes and unless I have unlock the doors or open and close the door again will they come back on.
E
Egor
Baltimore, MD
Right that's what mine do but they stay on for like 15min that cannot be right it's way too long and burns them out
R/T_Fire
Pleasant Grove
Might be able to change that setting with the dealership, not sure if a starscan tool will pick that up as a variable or a on/off toggle, but its worth a conversation with a GOOD service writer at the dealership...
BlownGP
Houston/Baton Rouge
Yeah, that doesn't seem right.
Even when you lock your doors they stay on for a long time?
RichieRich3030
I hate it when I "open and **** the doors"...
joshhhh
