Pump timing on eco diesels
bradpc987
OH
Wondering if anyone knows anything about the timing on the injector pump for eco diesels
crazykid1994
Isn’t the eco diesel run off fuel injectors and a high pressure pump? Not a mechanical injector pump.
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
Its an electronic injection but there will be a timing procedure, it is controlled by the ECU.
B
bradpc987
OH
I heard the pump needs to be timed to the cam
crazykid1994
I don’t think that’s how that works for the eco diesel given the injection timing is electronic with the injectors. To change injection timing would require tuning. The old Cummins with a mechanical injection pump you could degree the injection timing and they sold stroker pumps to increase actual injection volume which is completely different than a common rail setup.
B
bradpc987
OH
Ok, just to be clear, the injector pump DOES need timed. As soon as I find a proper explanation, I will post it.
