Put Royal Purple in the truck today
URdone21
CA
2013 Quad Cab
Just wanted to say thanks to everyone for the help and advice regarding putting synthetic into my truck and what brands are best. Same goes for the oil filter. Special thanks to Burla for all his help and knowledge.
DatacomGuy
Tampa, FL
Sweet. I need to research more before i do my first oil change. Are there any threads on here that helped you make your decision?
I need to source RP and Amsoil and see whats available locally, and at what pricing, etc.
Chewy
Bettendorf IA
V8
You can get RP at most auto parts stores and there's a million people selling Amsoil in the U.S.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I ran RP in my 03 hemi for years with great results. I switched over to Amsoil after going with the 370" stroker, but that was just to say that I tried something different. Never had an issue with either of these brands.
Arctic-Rodz
RGV, TX
6.7L Cummins
how many qts do these trucks hold? im @ 800 miles on my new truck.
Im also debating what oil to go with when its due for its change.
Im assuming the oil from the factory is conventional and not synthetic right?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Correct and as stated it is 7 qts with filter.
$miley
Etroze86
Grand Forks ND
Make sure you buy 8 qts though. Every Ram I used to change oil on at a dodge dealership took between 7 and 8.
DatacomGuy
Tampa, FL
What weight are you guys using?
And how frequent are you changing your oil with the RP stuff? How many changes are the filters good for?
Sorry for the noob questions..
mattman_13
The book says up to 8k miles max to maintain warranty. I would advise at least that for warranty reasons. I did 5k, 5k, 6k, 6k. With extended filters and Mobil 1. With the rp filter and oil I intend on the full 8k.
Burla
2010 Hemi Reg Cab 4x4
Check below for the synthetic thread, you can't go wrong with either of those choices. Also, just as important find a filter with synthetic media, I know Royal Purple filters have great construction for extended oil chnage intervals. Whatever filter you use, double check it after your first change. Cut it open and see if there is any stiffness or rips in the media etc.
TXKID
Houston, TX
5w-20
I'll try and change my oil every 5-6k miles, but you could go for 8k with no problems, and I replace my filter every oil change but I'll usually only get a k&n filter.
URdone21
URdone21
CA
2013 Quad Cab
I also put in the K&N high performance oil filter model #2010
Fatboy1989
