ok...........
So, here's the fun part. You have to trigger the high beam projector's solenoid from the low beam.
so......
Driver's side:
- little more fun, as you have to get your trigger to the relay harnesses for your HIDs from the drivers......but all good.
- From the H11 connector inside the light, you need to put a splitter on that, which one side will go to the matchbox solenoid. the other goes to your HID harness input for the low beams.
- from the 9005 connector (highs), another splitter. One side goes to MH1 solenoid, the other to the high beam HID harness input.
Pass side:
- inside the light you have the factory wiring........you need to connect the low beam wires to the matchbox solenoid. Connect the high beam wires to the MH1 solenoid.
This way..........when your DRLs are on, your solenoids on the matchbox are NOT activated. In low beam mode, the lows come on. The matchbox solenoids drop. The highs aren't on, so....all good. In high beam mode, both lows and high beams are on, solenoids on the matchboxes are already dropped, and now the MH1 solenoids drop.
Clear as mud?
