quality tailgate light bar
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I just got an opt7 last week.. Love it!! The length was a little off and had to remove the plastic grommit for spare tire key. $90 for the one i got but it adds a great look to the truck
I take it you didn’t need that adapter module thingy? Or does your truck even have a backup camera, park sensors or a trailer brake controller?
I do but I’ve had my little utility trailer plugged into my truck with no issues other than having to manually turn the rear park assist off for the trailer itself.
Seawri
Syracuse ny
5.7 v8 hemi
My truck is basic. No backup camera or park sensors. I dont have a trailer brake cont. Either. It was a simple plug and play for me.
Buzz
Connecticut
2006 Power Wagon
Hemi 5.7 pullin the War Wagon
Now I gotta start thinkin about cameras...Will upgrades ever end...No.
snobnk
hemi
I just heard back from putco and they are sending out new light bar that is updated and my dealer said it even has a new sku..we will see?I have heard this before
corneileous
Podunkyville, OK
-B-
Northshore of Boston
OPT7 is good stuff cheap mine has enured 3 New England winters with zero fading or hint of an issue , with a Curt 5 pin adapter installation was a breeze .
BIG RED HEMI
Lakeville, Minnesota
Hemi 6.4L/392CI
Gone thru 3 Putco blades in a year, now number 4 when installed failed immediately. My shop is talking to PUTCO now to try and resolve.....
I've had a Putco Blade on my truck for about 1 1/2 years now with no problems. Now watch, something's going to happen, thanks! LOl.
-B-
Biggest tip I can give on installation especially if using the press on adhesives is prep the painted surface good , IE I did the prep 3 times I use alcohol and a metal/ paint prep.
OnSale
5th Gen Crew
Philadelphia, Pa
I've got the Opt-7 60led tailgate bar and it's been on 2 Rams now. Went through 2 harsh northeast winters and even when I got rear ended it was undamaged. I swear by the Opt-7 led tailgate bars. Either I got a super rare invincible one or they are all rock solid and extremely well made.
7beb98e6c46645da581d7a0b3c22b2a1.jpg398b4d7bd022ddc90cb545d1f10ea67e.jpg6524e59d04e00d132eb66f4326dcf29e.jpg
Bo Daggart
5.7L
My opt7 just showed up. I already hooked it up to test the lights. They all work.
Great packaging too. Inside a plastic tube then inside a hard cardboard tube with a piece of wood taped to the side for extra strength.
Ive seen install videos for installation and the all run the back up wire to the tail light. I think I'm going to attach mine to my railer harness.
corneileous
Podunkyville, OK
I think the reason they instruct us to run that back up light wire to the bulb in the tail light is because we don’t have a backup light circuit in the pigtail plug.... There’s a 12-volt circuit that comes off the battery to run accessories on s trailer but I don’t think there’s on for backup lights. 2e8dfc681d11c73cafaf6ed084bebf56.jpg
corneileous
Podunkyville, OK
Hmm, white is supposed to be ground.
corneileous
Podunkyville, OK
I don’t know, since there’s so many different configurations for 7-prong trailer plugs out there, maybe we do have a reverse light circuit, I have no idea. I’m not near either one of my two pickups to go look but I would say that if we do have a backup circuit in our plugs, use it. Who knows - when I put that Anzo light bar on my old truck long time ago, I probably didn’t even have to pull the taillight out and tap into the wire up there but I definitely most certainly will be checking into that this weekend when I go to install my new lightbar on my new truck.
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
You are correct. I was thinking the Wire is the White wire on the Bar.
corneileous
Podunkyville, OK
Lemniscate_Mike
