I have a 2015 ram 1500 V6 with 3.21's and just put a leveling kit with 35" Cooper AT3's.
My problem is it never wants to shift to 7 and 8. I know that the truck thinks I still have the factory tire size so that causes some of the issue and that the tires are heavier.
I need to know what if any is the best way to solve or lighten the change.
So here are the questions I have;
Would buying a Diablo Tuner and PCM to change the tire size help any or will that just fix the speedometer issues?
Are there any other parts or things that I can do ?
Also I have searched through threads and found a lot of material but no that applies directly to my circumstance so that is why I am posting. If there is a thread that already exists I apologize in advance. I am grateful for any input you guys have.
That is a seriously bad combination of power/gearing/tire height&weight. A V6 with 35s is going to need some low (high numeric) gears to feel anything but anemic. Even if you had factory 3.92 gears, the V6 with 35s would likely feel sluggish. 4.56 gears should do the trick (4.10s minimum)...it's what Taco owners with V6 engines and big tires do all the time.
