Question on Manual Trailer brake controller
J054UA
Louisiana
So I did the Trailer Brake controller install and used alpha obd settings to program. Checked all four settings again and they all set to the correct values. Without a trailer the gain minus and plus show up on evic and when I hit the brake pedal with the trailer screen on the evic. The gain goes up and down with the brake pressure applied.
But for some reason when I manually try ajusting the sliders by themselves without a trailer connected. A red screen pops up with the message Service Trailer Brake System and goes away after letting go of the sliders.
I did not see no faults or codes in alpha obd, no messages in evic, was told by infotainment that’s normal since no trailer.
Not sure if thats correct so Im asking on here.
I’ve seen videos on YouTube of individuals just using the sliders to show the gain with no trailer installed and it shows the gain on evic. Just making sure I don’t have a faulty unit and I dont know anyone with a trailer to test. Just double checking to make sure if I go to use it in the future it will show up when it’s connected.
J054UA
J054UA
Louisiana
Now its not working at all. Go figure and message popped up on messages saying evic service trailer brake system.
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
There are 5 settings to change:
1. CBC Features:Trailer Tow Present
2. Cust.set.menu2: Trailer Selected CSM Present
3. Cust.set.menu2: Trailer Name CSM Present
4. Cust.set.menu2: Trailer Type CSM Present
5. P/T Chassis Net: ITBM/HWM Integrated Trailer Brake Module
J054UA
J054UA
Louisiana
Done all five man and checked to make sure they were all activated.
jservay
New York
Is it normal for the trailer brake to display when braking, if there is no trailer attached?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Nope, unless you have it selected to display in the EVIC.
Is yours an OEM / dealer installed unit or aftermarket? I would say either the switch or the controller are kaput. You could also have a wiring / corrosion problem back at the trailer connector or the wiring connectors back there.
If aftermarket one is installed, get a an OEM unit, not the Chinesium hit or miss junk from Amazon. Mopars don't like aftermarket electronics.
