Question on the dual usb charging port
Astrodudes
Canada
Hi,
I’m trying to figure out the wiring for the dual usb ports in my truck.
My understanding is that red 1 is 12V positive, 3 is for illumination light, black 4 is negative. But when I connect 1 to 12V + and 4 to 12V -, the port does not work. It only works if I connect 1 and 2 to 12v +. Can someone explain how the wiring works and if there will be an issue if I connect 1 and 2 together to 12v positive?
tron67j
Maryland
Agree with red and black. But think orange and pink are data. I am trying to remember from my computer building days, but think a USB for charging only just has 2 wires, 4 would be power and data. Maybe someone else can chime in and correct me if I am mistaken, but think that is correct.
Infotainment.com
Supporting Vendor
Orlando, FL
2016 Ram 1500, 2019 Ram 2500
Hi,
That USB port is for charging only, no data lines.
Connector Views
Mating Side:DvwqRI7AvgJfnXl5dLvwQ__&Key-Pair-Id=K1E5YH0AOTG587.gifWire Insertion Side:YzoyM0dEONuYqMvONQW5g__&Key-Pair-Id=K1E5YH0AOTG587.gifIsometric View:gA53eNQdXUndSt9IJOBJA__&Key-Pair-Id=K1E5YH0AOTG587.gif
Location Views
StandardView
PinCircuitWire ColorGauge/SizeFunctionOption
1A936RD0.35FUSED B(+)
2E12OG/GY0.35PANEL LAMPS DRIVER
3F781PK/YE0.35IGNITION RUN ACC
4Z912BK0.75GROUND
Arturo Rojas
