Question: What brake fluid does a 16' RAM 1500 Laramie take?
sullivan
Houston, Texas
For the life of me I can't find anything solid on it, my 3rd gen RAM 1500 took DOT3.
Look on the side of the brake fluid reservoir, it states DOT 3.
DOT 3 & DOT 4 are compatible, just 4 is rated for a higher temps, not needed unless you decide to start racing on a track.
If you really want to push the high performance there is DOT 5.1 but you'll want to flush the entire system. Do not use DOT 5 as it is completely incompatible with brake systems that were not designed for it.
Dark Knight 500
Alberta
Dot 4 is best if the truck is gonna do any amount of work.
