Questions about lowering 4wd trucks?
Gus
Hello i have a 2014 ram 1500 sport crew cab and i want to lower it instead of lifting it i was wondering how low could i go without affecting suspension/ cv angles and such and if i was to just lower the rear how big of a tire would i be able to run looking at replica 22" srt10 rims thanks for any inputs
Sillygoose
NY
2/4 is as low as you can safely go.
i have the rear dropped on a 305/45/22 srt replica. it rubs the front sway bar at full lock. also rubbed the upper control arms, took a grinder to shave some material off. all is good now.
Etroze86
Grand Forks ND
I have the GF 2/3 kit on mine and love the stance it gives my 4x4, and as stated above I believer 305/45/22 is the biggest and I think ive seen the 40 series used many times as well.
charonblk07
Calgary, Ab
F1-A forged 349ci
2/4 is the lowest if you just want to throw a kit in it and be done. I'm probably the lowest 4wd on here at 4.5/6.5 and I've done a lot of specialty work to keep everything happy.
G-Truck
HEMI 5.7
I copied Etroze86 with a GF 2/3 . I am running Mopar R/T wheels 22x9 with 305/45R22 tires . Not one rub anywhere ever ...
G
Gus
does it rub since the wheel is 10 inches wide or how wide the tire is ? and does it rub on the control arm when you turning or just rubs all the time before you trimmed it
Sillygoose
NY
tires rubbed the control arm all the time before trimming
charonblk07
Calgary, Ab
F1-A forged 349ci
Whats the widest i could go without trimming
9" wheel but pay attention to back spacing, you don't want anything more than a ~+20 offset/~4" backspacing. A zero offset will be your best bet if you're getting aftermarket 9" wheels.
G
Gus
i want the 22 srt wheels unless i get like a 0.5 inch spacer
iceyivy
California
6.7 cummins
Sounds like opting for 4x4 when you bought the truck wasn't necessary...
G
Gus
i need 4x4 since it snows for more then half the year just dont want to lift it like everyone else.
charonblk07
Calgary, Ab
F1-A forged 349ci
The problem is the SRT10s are a 10" wheel with a +25.4 offset, gives you a ~6" backspacing. You'd want at least a 1" spacer to get back to a zero offset and a 5" backspacing.
Reactions: Gus
G
Gus
Thanks for the help if i go that route ill have to buy spacers then. i just cant seem to find rims that i like
Sillygoose
NY
Correct, most do spacers as opposed to grinding
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I just installed a new set of 20x9 +18mm offset wheels on my crew cab 4wd with 305/50/20 tires, and I don't have any rub at all. I am also running the Ground Force 2/3 drop.
G
Gus
Nice!
mvm2
