Questions on modding
Trysten Hawki
5.9 liter
Hày I'm starting to want to little and modify my truck. I had a97 Dodge ram 1500 regular cab short bed 4x4. I'm wanting to lift it and put bigger tires on it possibly repaint it or wrap it and got a few questions that I want an answer from someone that thinks the same. I want to put about a 6 inch total lift all around. Now my first question is which lift kit is the best for the buck I don't want to buy super expensive parts but I don't want trash I will end up beating it up. I'm also wanting to put bigger tires on currently hav16s I'm thinking 18s maybe. I need new wheels and tires for fourwheeling probably more rock and mud my second question is what tires and wheels set would be good. I am getting front and rear bumpers so if you have suggestions on them too that'd be great. Just try to keep the price lower I am just starting to mod it. I am including a picture to give you all an idea if you can help and have any pointers that would be great anything helps.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Lifts aside, as I know little to nothing about them. To put larger tires on that you will also want to regear the truck, for 35s you should go a minimum 4.10, 38s really do require 4.88 or higher.
ramburger
5" skyjacker and 35's is a good start.
it will be sluggish but driveable
gears is expensive but a must soon after ya get it up
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I have a 3 inch coil lift in front, and a 4.75 inch lift in rear(stacked stock blocks) with 35s, it is great and I ride high up, but it is a bit sluggish, even with O/D locked out. You can do it but if you regear you'll love it. I simply don't have the cash to do it anytime soon. Running 3.55 stock gearing.
