Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I read that the 2014's had a neutral disconnect for the front axle. Supposedly allowing for 1mpg increase. Not much info on it, and not sure if that's the button or not.
It isnt a neutral disconnect in the front axle it is just a front axle disconnect. It works whenever you are not in 4 wheel drive. The button you are referring to puts the transfer case in neutral so it can be flat towed.
