Quick question regarding LED bulbs
AngryRams
Phoenix
I got my plug n play led set today. I plan on installing them for my low beam. It is the cougar motors LED h11... Is the canbus adapter absolutely required?? Please advise so I don't waste my time tonight...
Sent from my SM-N950U using Tapatalk
Mbrigh3
IG: Stormtrooper_5.7
MD
you have a 15. Most likely youll need that adapter.
AngryRams
AngryRams
Phoenix
Okay.. ugh I just see so many different answers.. not sure if people are trolling or if it's luck... Should I try it? I'm gonna order the adapters tomorrow regardless.. but I see others saying they didn't need them.
zrfraser
3.6 Pentastar
You'll need them if you have a 15 for sure.
If it's a '15, most likely they work without the CANbus adapters...
....till you start the truck...lol
(yes, been there, happened to me)
AngryRams
AngryRams
Phoenix
Not worth trying ? I'll order same day delivery from Amazon tomorrow. Can anyone link me what it is I need from there?
It's the cougar motors h11 plug n play... Or so they said [emoji24]
AngryRams
AngryRams
Phoenix
AngryRams
AngryRams
Phoenix
I had a set of Opt7 in my fogs and used the CANbus adapters they supplied. One started to act up and bought a set of Diode Dynamics Anti-Flicker modules. I still use them on my Morimotto XB vertical fogs.
https://www.diodedynamics.com/canbus-anti-flicker-module-pair-connectors.html
Well I got them both in... But like y'all said they turn off once it's turned over... I'll be ordering the canbus module first thing in the morning for same day delivery.af56f2a3b03f6dac0a8b134a493d1172.jpg7de5a4fbd7f1911eae65cf45f9567688.jpg
AngryRams
AngryRams
Phoenix
Not entirely dark out so it's a bit underwhelming in the photo.
AngryRams
AngryRams
Phoenix
Well I ordered these... Anyone ever use them? f497ef03f9c62bc8beabcf3ebc05d9e1.jpg
walnuts4x4
Northern NY.
2018 express crew
Following since I wanna do the same thing...
Sent from my Pixel 2 using Tapatalk
AngryRams
AngryRams
Phoenix
I'll report back as soon as Amazon delivers the package and I install. I'll probably prep the truck that way I can plug it in and go..
Fyi this was last night... Not entirely dark out either.f2f3362b600b1c4c1ae7e706e5a824f9.jpg
AngryRams
AngryRams
Phoenix
They work. Will report back tomorrow night if any issues occur.
AngryRams
AngryRams
Phoenix
No issues. Really bright. Got flashed by what I suspect was an old guy last night due to the neighborhood I was in. And then a little audi turned on their flashers cause I was lighting em up like the police... Lulz
MarshRam
2014 SLT 4x4, 2012 ST
Getting flashed that much already is probably not good. Maybe adjusting the lights downward will help. Gonna lose distance and some sharpness in the cutoff with those leds in that setup anyway. I have a 6 inch lift and put leds in the same housing, have the lights adjusted downward, probably more than they need to be, but I don't get flashed.
