Quick wheel question
asierra1
Going to be purchasing some new wheels this week, but would like a bit of input first. Truck will be leveled with bilsteins at 2.8.
Wheels are fuel d560 (vapor)
Wheel specs are 20x10 on a -18 offset. Can't find the backspacing anywhere.
Think they'll clear?
jsteinm1
Nebraska
2014 Ram 1500 Sport CC
HEMI 5.7L
The wheel itself will clear no problem, the tire is the concern. What size tires are you running? Someone should be able to chime in.
I haven't lifted mine yet, but IIRC right from reading around here you should be fine with about any 35" tire with the bilsteins and a slightly negative offset.
A
asierra1
Tires will be 35/12.5/20 toyo r/t.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
They're going to rub on the back of the inner fender plastic. But you'll be able to fix that will a little trimming.
