Escotch
Hi all,
I’ve been working on adding a backup camera to our newly acquired 2014 Tradesman per wifey’s request. This is the nicest vehicle I’ve ever owned and wanted to keep it looking clean and stock on the inside so I found an RA2 on the forum and ordered an OEM backup kit.
Installation of the kit was tedious but I’m pretty sure I did it right. I worked slowly and followed posts and guidance here on the forum.
When it came to installing the RA2, I didn’t realize I would need more than the VIN to obtain the security code so things went like this:
1. Install RA2, reconnect battery, turn on the ignition
2. Radio requests code - shoot, don’t have that.
3. Turned ignition off, pulled out radio to get relevant numbers, input into site referred by the seller and wait for code.
4. 15 minutes later I have the code in hand, turn the ignition on, and....the radio doesn’t ask for the code?
I figured, “Hmm...maybe that is just an easy work around for not entering a code?” but then I realized that while the radio turned on and I could navigate the screens the volume knob would not adjust beyond 0-1 and there was no sound.
Crap - did I just lock this thing out by not entering the code on first startup?
Then I cycled the ignition a couple times and boom - it was working! My joy was short lived though because when I came out the next day the volume was back to 0-1 and would not adjust. After 2 days of no sound I have pulled out the RA2 and put back the RA1. RA1 works with no issues.
So, did I “lock-out” this RA2? Is there a way to fix that? Or is something else wrong?
Also, I was optimistic that the backup camera would display without a dealer flash since the RA2 came out of a backup equipped truck - this has not been the case. Is that typical?
I appreciate any input you may have.
Thanks,
Scott
Thanks,
Scott
