Radiator supports.
84D100
Greeneville,Tn
What is the crossover years for the radiator supports? I have good 90 model support I need to use on my truck. What year grills will fit? If I have to I may cut and redo the buckets so i can keep my 84 grill.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I may be wrong, but I think the 81-90 core supports will work with either grille. 91 is when they changed them a bit I think.
crazzywolfie
under the truck
86-90 grills are the only thing that will look proper on a 90 rad support. a 81-85 grill will work on a 90 rad support but the headlights look funny. i think the stick out a bit and sit a bit higher.
84D100
Greeneville,Tn
If its real bad I can always cut and modify the buckets to get the lights to sit right.
