Radio Problems
thegreat22
2015 Ram Express 1500 CC 4x4 - Black Edition
I have a pioneer AVH-X570BHS. Truck is a 2015 ram. At first the radio cut on just fine and played. After shutting vehicle off and truning back on, I have no sound from radio, no pioneer beep nothing, radio cuts on though and I can scroll through all the menus, but no sound .If I connect up factory uconnect radio it plays fine ,and everything works. Is the internal amp in the pioneer fried? Any hep is much appreciated.
Etroze86
Grand Forks ND
Are you using rca's for an amp? Did you swap them when the vehicle was running?
Sent from my SM-G920V using Tapatalk
T
thegreat22
no amp and no swap while running
adrianp89
Tampa Bay, FL
Get a spare speaker... any one will work.. and hook it up to one of the speaker outputs of the radio and see if it plays, if it does then it is your harness that is bad. I would guess it is probably the harness, especially if you used a Metra one.
T
thegreat22
ok will do, used an idatalink maestro ch3 harness
