Ram 3500 short bed Hemi large gas tank
GauchoMarksRacing
Chico CA
hemi 6.1
Hello everyone. New owner of a 2022 3500 short bed Hemi. Mileage is terrible of course. No information that I could find on gasoline extended range tanks. All polymer tanks state Dielsel Only.
Is this an EPA issue or will these tanks not work with gasoline? I aplogize if this has been asked, searched, did not find anything. Mark
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I believe in Chico, there is a big company that makes fuel tanks
It may be called Transfer Flow
Their tanks are made of diamond plate, but there is a plastic inner liner
Titan is another fuel tank company
You can look at their websites & their brochures may have answers to your queries
GTyankee
3.0 ecodiesel
Can you put gasoline in a poly tank?
Volatile chemicals with low flash points, 140 degrees F (flash point) or less should not be stored in polyethylene tanks. Storing these types of chemicals, like gasoline or xylene, in a polyy tank is dangerous.
6.7CumminsDrvr
The Dude abides………
Georgia
No extra capacity drop in replacement or aux tanks available for us Hemi owners. There are transfer tanks that are gasoline rated, Transfer flow has a couple for example. If you’re real ambitious, you can piece together your own aux tank setup. I found a few tanks rated for gasoline that are set up so you can build your own legal aux tank, have to buy a pump and components for the neck filler, but no one sells a “complete” kit. I just installed a Titan Sidekick in my truck and bought a Terapump, works good enough for now.
Glowz
