ram classic bezel question
WillMils
Harrogate, TN
hopefully someone here knows the answer to this and If this part even exists, can someone link me to a nice used one or new. I need the 8.4 bezel that doesn't have volume knobs. I have bought a jeep Cherokee 8.4 nav unit to upgrade my ra2 and of course the bezel isn't gonna be right unless I get creative and make one. FYI it's for a 2019 ram Classic, thanks in advance
Ricks Ram
Contact Mike @M2mods in the vendor section of the forum. He makes the harness to convert your truck plus usually has the 8.4" bezels in stock. He can answer all your questions and get you set up.
Sent from my SM-G981U1 using Tapatalk
dwhutch
NC
I don't think there is a Ram 8.4 bezel without a volume control. All I've seen have volume, fan speed and tuning. Some have dual zone climate control and some are single zone manual. Only thing I've seen without volume control is aftermarket from Infotainment, don't use them if you want the factory bezel, see Mpgrimm2 for the adapter harnesses needed. If you go with the aftermarket you can only control volume with steering wheel controls, if you don't have those you're out of luck.
Sent from my SM-G970U using Tapatalk
deathbyburito
Minnesota
3.0L EcoDiesel
Do you mean an 8.4 bezel that doesn't include the volume/hvac controls like the attached image or one that has no space for a volume control? Not sure the second exists.
W
WillMils
Harrogate, TN
thanks for the responses. I have messaged Mike about the harness and all. I think the answer was , when you go to the 8.4, you have to have volume knobs on the classic because the 8.4 radio doesn't have knobs. other than that only other way is to add steering wheel volume buttons. aside from the other issues with the hvac that it creates and the added nav now. wish me luck
tron67j
Maryland
I bought one without the volume control from infotainment.
