Ram died today
stimpy433
IOWA
Well I ran a couple of errands today and my last stop was the home improvement store. Run in, grab my stuff and back out to my truck in less then 20 minutes. Unlock the truck, and go to start it..... turns over, runs rough for about 30 seconds then dies. I try it again and cranks but no start, so had to get it towed to the dealership. I tried it one last time before the flatbed showed up and it would run really rough for a minute or so then die. To me it reminded me of the old car I had that the fuel pump went out on.... only 12K miles on the truck. Will see what the dealership says Monday.
14hemiexpress
6.4l
Had you recently gotten gas? Sounds like possible bad fuel. Happened to me once.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
If a hammer doesn't fix it, it's an electrical issue.
Here's hoping it's something simple, man.....
stimpy433
stimpy433
IOWA
I did get gas about maybe a half hour before this happened..... so I did let my dealership know about it.
TerraNewf
NL, Canada
I would love to know what the problem is, good luck with it
RamCares
n/a
n/a
Hi stimpy433,
Let me know if you would like me to follow up with your dealership for you!
Andrea
Ram Social Care Specialist
Bigbird
Arlington Texas
2017 RAM 1500 QC 8sp, 3.21, Lone Star
Stopped up fuel filter? Happened the same way with a Ford F-150. It was running fine on the highway. Stopped at McDonalds for a 15 minute break. Went back out and it would start briefly, run rough, and quit. Then finally it would not start at all. Had it towed about 100 miles.
gisboro
South Carolina
Sounds like diesel in a gas truck, hard to do with the difference in nozzle size but I've seen it happen.
stimpy433
stimpy433
IOWA
Not diesel, they only have one pump for that at the place I filled up and I always do a double take to make sure I'm getting the right octane gas.
stimpy433
stimpy433
IOWA
Hi stimpy433,
Andrea
Thanks Andrea, so far the dealership has been great, they even gave me a loaner with out me even having to ask!!!
tmletourneau
SE MN
Well that sucks but at least it should be simple to fix.
Sent from my SM-T817V using Tapatalk
Treburkulosis
Your High End Detailer
Haslet, TX
Did you get a decent grade/brand of gas? I noticed a huge change in mine in the way it seemed to mis with quick trip gas vs the Exxon I have been putting in it for 2 months now. My work truck is a 02 Silverado. It's pretty much maintance free and we got some bad gas at quick trip and it was surging in the idle and it died several times. I had to end up putting chevron gas in it and after a few miles straightened up. I worked at a full service chevron gas station as a pre teen pumping gas and I heard horror stories about lesser companies watering down the gas. I don't know how it works now, because of all of the ethanol crap they add it to our gas. I hope it's just gas for you.
JustinRam1500
