Ram Rebel Conversion Parts
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi Moises, From our research and what our parts data shows all of those parts are unique for the Rebel and are required for a proper conversion.
Please let me know if you have any other questions.
Thanks,
-Benny
MCMLXIX
Las Vegas
5.7 HEMI R/T
Would you have a part number for the Rebel instrument cluster bezel/mask with red rings?
Just the front of the cluster, not the entire cluster...
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Sure it's 68280858AE
Thanks,
-Benny
MaxSteel2013
We have been getting alot of inquiries for Rebel specific parts info so I have started this thread with links to popular requested parts. Please feel free to reply with a request and I will add it to this list.
Front Bumper Parts
Outer Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271501ac
Inner Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271506ab
Lower Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-bumper-68271516aa
Bumper Closeout Kit https://parts.allmoparparts.com/oem-parts/mopar-close-out-bumper-68271570aa
Bezel Kit Lamps https://parts.allmoparparts.com/oem-parts/mopar-bezel-bumper-68271564aa
Bezel Kit Tow Hooks https://parts.allmoparparts.com/oem-parts/mopar-bezel-tow-hook-68271565aa
Lower Grille https://parts.allmoparparts.com/oem-parts/mopar-grille-lower-68271566aa
Front Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-front-5sx95rxfab
Left Headlamp Filler https://parts.allmoparparts.com/oem-parts/mopar-filler-molding-55372919ad/?c=aT1USDEzMDA1NSZyPTI=
Right Headlamp Filler https://parts.allmoparparts.com/oem-parts/mopar-cap-front-bumper-upper-55372918ad
Bracket Kit https://parts.allmoparparts.com/oem-parts/mopar-bracket-hider-panel-68340904aa
Lower Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-front-5sx96jscac
Left Brace https://parts.allmoparparts.com/oem-parts/mopar-brace-front-bumper-68253755aa
Right Brace https://parts.allmoparparts.com/oem-parts/mopar-brace-front-bumper-68253754aa
Left Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-55112807aa
Right Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-55112806aa
Left Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-68251641ab
Right Splash Shield https://parts.allmoparparts.com/oem-parts/mopar-shield-wheelhouse-68251640ab
Left Front Fender Flare https://parts.allmoparparts.com/oem-parts/mopar-molding-wheel-opening-flare-1fv91rxfae
Right Front Fender Flare https://parts.allmoparparts.com/oem-parts/mopar-molding-wheel-opening-flare-1fv90rxfae
Fog Lamps (2 required)
https://parts.allmoparparts.com/oem-parts/mopar-fog-lamp-assembly-55112827ab
Rear Bumper (Powder Coated Black with Dual Cutouts & Park Sense)
Rear Bumper https://parts.allmoparparts.com/oem-parts/mopar-bumper-step-68271591aa
-Benny
@knightjp
Dale Frost
Ontario
Hi there sorry to bump an old thread, do you have part numbers for 2021 warlock tow hooks? I believe they should be the same as 2018 rebel tow hooks, that are in fact different from the regular DS tow hooks......?
Ramzit
Oregon
Benny,
Will the entire front end rebel conversion work on a 2014 tradesman?
Philly_teee
Toronto
Hi Benny, I think I want to order this. I have a 2014 ram 1500 slt. Is there any other parts I need to make this fit? Is this all direct bolt on or are any modifications needed?
also, I was looking at the parts list because I am in Canada, I have to use the Canadian site. I only saw the lower grille and not the main upper grille with ram lettering. Did I miss that or is there a part number for that?
48PowerWagon
Bellingham, WA
Ask Benny to check on stock levels and be aware of your mod's time frame I've had 2 orders in since early April that are still "in process" NOT Benny's fault, just the supply chain
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
You would need the grille which I did add on the first page. Here is a link as well
https://parts.allmoparparts.com/oem-parts/mopar-radiator-grille-5uq43rxfab
- Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Agreed things have been bad in this regard but in all honesty we are backed up as well so its a combination of things. We have new staff in training in order to speed up in stock part orders but the backorders will continue to be an issue.
Please let me know if you have any questions about an order.
Thanks,
-Benny
Philly_teee
Toronto
Philly_teee
Toronto
thank you for the heads up. I appreciate this, will call re: inventory first. Thanks again!
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Thanks Benny, I picked up a used bumper, skid plate and brackets today so I’m ready to go on this. Is there a list of nuts and bolts that I will need?
Sorting out the hardware is the hardest part. Mopar does not detail this very well. Check the first post as I uploaded a PDF of all the parts data.
- Benny
Philly_teee
Toronto
- Benny
Hey Benny,
looking at the pdf in the first post that you uploaded is that all the hardware I need and are those the quantities I need them in? (what’s stated in the PDF)
Thanks so much
Philly_teee
Toronto
Also, is there a write up on how to do the swap/where the hardware goes?
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hey Benny,
Thanks so much
The part numbers are there but the quantities are not, This is the problem. Sorry we do not have a write up.
-Benny
stembridge
The Middle South
Pentastar 3.6
Benny - is this list of parts also applicable for converting a 2021 RAM Classic Tradesman to the Warlock bumper/grille (which appears to be the same as the Rebel)?
es
sigsauerP938
