Rambox plastic end caps
Granite Ram
Canada
Does anyone know what’s under the front and rear plastic end caps on the rambox?
Just wondering if it had steak holes under them.
Damion
2019 Sport
I don’t think there’s anything useful under them. If I remember right if you look under the box up at where the caps are, you can see the bottom side
HitchHiker
Delaware
Since there are drain plugs under both endcaps, while I haven’t looked myself, I’d surmise nothing of note.
Davis MacD
Richmond ca
A Quadcab dakota lumber rack's four legs will fall dead center on the plastic pads. I could cut off the rails and weld flat-stock feet to the legs and match the plastic pads perfectly, centered and all. But is there enough supporting metal to carry a Drake 10' rack? I want to dump my dakota for a rambox. In the SF/bay area the rambox has a lower resale than standard bed. I think because the rambox is attractive to thieves.
Reticle918
