RC 2" loaded leveling struts
Gary2
S Jersey
They are easier to install but then you have pretty much a one size fits all spring rather than the factory one that matches your trucks weight exactly . MOPAR used many different springs on our truck depending on trucks configuration for a reason. That is the main reason ya see negative comments about the amount of lift from the Ranchos, one spring don't lift all Ram 1500's the same amount.
sstumpf
sstumpf
Central IL
That makes since. I kinda want to try these, but I know I should probably just go with the 5100's.
