RC Custom Ported Box Build two 10's
2012TrueBlueRam
Jacksonville, FL
After planning for awhile I decided to put two 10" kicker CVR's in a custom built ported box, powered by a RF R1001.1d. The airspace requirements were a little tough to meet without sacrificing space. If my measurements are right the seats should still slide and lean all the way back without interfering with the speakers or ports.
View of the passengers inside of the box, with the center support all cutout to equalize pressure in both sides.
Every interior corner is rounded to prevent any inferior port noise, and out just looks good.
The top, datos and rabbits all cut and ready to put together.
The back, with a cutout for the seatbelt built in.
View from the front, only thing missing is the faceplate, being glued together and some final sanding, and carpet before the speakers can be installed and put in the truck
Any input is well accepted, thanks for checking it out.
BTW, first thread with pictures, hopefully it's right, if not, I'll figure out.
quietpeen
2021 TRX
Hellcat
looks great...bet that is going sound awesome
2012TrueBlueRam
Jacksonville, FL
Hopefully it doesn't take to much longer. Between work and the holidays it's slowed down alot. This weekend I should be able to pull the seats and run all the wiring under the carpet, and mount the amp. Then it'll just be set the box in place, plug the wires in when it's finished.
WhiteExpress
Midland, TX
How are you covering said box?
*EDIT: Then I learned how to read...*
Texas Hemi
Orange, TX
Impressive. It looks like you have done some quality work there
2012TrueBlueRam
Jacksonville, FL
I'm looking forward to hearing it finished, should sound awesome. Work is killing me though. Planned on getting some time in on it today, and got stuck working 16 hrs, gotta fund the project somehow though.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
be a little much power wise on two CVR 10's...whats tuning and SSF set at?
noraa73
