Rear Bilsteins
2016 Longhorn
So if you go with Bilsteins set at 2.8 on the front and Bilsteins on the rear do you still need a spacer to level out or do they lift you an inch in the rear?
chipmaker
AZ
The Bils for the rear are not lifting shocks. Install spacer to lift the rear if you want.
PassivAggressor
They don't give you any more lift on the rear.
misuracaf10
If they do not raise your truck at all, what are the advantages of using bills in the rear compared to stock? Do they have a better ride/performance when combined with a rear spacer?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
It's been said they improve the ride. If they are anything like the front, I believe it.
That being said, I did the front to level and will leave the rear until they are worn out. Then I'll put Bils on the rear as well.
Do you have any pictures of your setup with bills at 2.8 in the front and stock shocks in the rear?
I am thinking about going this route, thanks.
sriley531
Ohio
Not a great angle, but it's all I got. Mine with bils at 2.8, rear all stock.
I put on TGC 1" rear spacers shortly after as it was a pinch nose high stock. However, after a few weeks the front settled and now I have a little rake, but I'm good with it.
looks great!
and those look to be your stock wheel/ tire setup?
sriley531
Ohio
looks great!
That's correct, factory wheels/tires (for now [emoji6] ) Here's a pic from the side after the rear spacer install to give you an idea. As I said, now that the bils have settled a bit, it'd probably be dead level without the rear spacers, but Im good with it.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Sorry, my truck is at 2.1 without a rear spacer on stock wheels and tires.
Even at 2.1 it seemed a little nose high, but it settled after about a month to level.
miguelherrera4
41fe092c85d864c8eaacb1c00505b575.jpg front set at 2.8 and rear stock. Got a spacer and tires coming tho:)
Sent from my Nexus 6 using Tapatalk
Cb1000h
Before
After:
Some gratuitous pics Next to My 5.9L and a buddies stock Chevy
Front Bils set at 2.1 (no Cv vibrations in 4x4) rear springs are Superlift progressive rate springs supposedly to be 2" over stock and Tires are Nitto 275/65/20 (34") on stock rims no rub anywhere under any condition
The My Red Dodge 2500 5.9L you see in the pic is running 295/75/16 (33". something)
over all the Ram is bigger than the Dodge at the Hood, roof, tire. The door sills and wheel well heights a slightly higher on the Dodge
Though I would have sworn otherwise if they were not side by side
I need to get rear Bils for a 2-3 inch rear lift or another manufacture if anyone has a good recommendation equal to or better than bils
I have only been able to find for 0-1 for 2013
does anyone know the part number for the correct set
The stock shocks are stretched to the end
next mods are a Vararam intake other suggestions appreceiated
phrater
Renton, WA
2014 1500 Express crew cab
My fronts are set to 2.1, stock rear, no spacer in the rear, 275/65/20 nittos. BUT my new rear bilsteins and tuftruck TTC1223V springs will be here next week!
RoadRamblerNJ
Mountain City, TN
392 Hemi
Before
After:
Very Nice! I kinda like that 5.9 myself. Sheet metal on the new trucks looks like it's all puffed up with air. It is. Older trucks just punched a smaller hole in the air.
I run a Headache rack 'cause rear glass ain't cheap.
Other recommendations from me always include this bar. It's the "Rancher Grille Guard" by GO Industries in Texas. I had the gloss blk powdercoat on my '09 1500 and I have the textured flat black tuff armour on my '17 2500. It's held on with four (4) bolts and you don't lose your tow hooks.
Here's a few pics.
PS: I hit 2 deer with the Red 1500 and so far I've got 4 with Big White. No repairs made. YOU find the damage, LOL. These things are Deer Slayers!
PSS: WTF is that on the front of that Chevy? A screen door? Lol.02755316d9fe46c97b64506c936a46ca.jpgc19d1d1fa04669d14c940666ee833cc7.jpg9b1701b88bee2c133678d8063e3bbbb3.jpg66ec0ea9b33567335d7a40d0e1c087ea.jpgc23af33da08961228b5e8d1654e10ee1.jpg
Reticle918
