FriedDumpling
- Feb 18, 2018
- 537
- 315
- Location
- Charlotte, NC
- 2015
- 5.7 Hemi
Bad camera or water in the tailgate harness.
Ends up that the camera harness connection is a weak point. The fix is really simple. Open the tailgate and remove the access panel for the latch. You will see some bolts holding the latch assembly. Loosen those and take the latch out. No need to take off the cables, just enough to get the latch out of the cavity so you have room. I have big hands... LOL. Unplug the camera. Clean both sides well with electronic cleaner. Add dielectric grease to the connection to assist with sealing out moisture and reconnect. I then carefully wrapped the connection with electrical tape, leaving a folded over tab to be able to easily remove in the future if needed. Replace the latch and button it up. Took me about 15 minutes to do, and two years later... no problems.
If that doesn't fix the issue, if it was me I would just replace the camera at that point.
