Rear coil spacer question
badjuju2010
I got my new rear coil spacers in from supreme suspensions and they are 2 different sizes.. one is 1 1/4" tall and the other is 1 1/2" tall.. is this on purpose for the "dodge lean" or was it a mistske? If its for the lean issue i need to have the taller one installed on the driver side correct?
badjuju2010
badjuju2010
Bump for help please.. im kinda freakin out here
Allstar
Arkansas
2012 Sport CC
contact the manufacturer. I would tend to think they were mismatched..
ATOM
i just bought a different kit from another manufacturer and the rear are both the same, sounds like they sent you 2 different ones.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
This looks like a mistake....BUT i would keep it.
Our trucks have a lean on the drivers side rear and it will lean between 1/4"-1/2" depending on your fuel in your tank.
I have purchased taller coil spacers for this exact reason.
If you are ok with this, throw the 1 1/2" on the drivers side (rear) and 1 1/4" on the passenger side (rear)
A few members here are doing this....non of them have advertised that they are doing this, but I know they are running like this.
A lift will even accentuate the lean even more
My 2 cents
