Rear diff oil for 2017+
Rickyd31
Montreal
IMG_3673.jpegI want to change my rear diff oil on my 2017 1500 ram. 3.92 lsd. C235
Owners manaul ( printed in 2016) said 75w140
Owners manual online said 75w90
Dodge checked with my vin and said 75w90
Who is right ? I bought both and i guess ill see the viscosity when i dump it. You can tell one is more liquidly than the other.
Daw14
South Florida
They changed the viscosity to gain a fraction of a fraction of mileage.
The 140 seems like it would be better for longevity ,and is what I would use if my truck was newer .
I have a 14 and it calls for the 140.
David H
USA RET
Minneapolis
Also, I believe that 140 you have, MS-8985 requires a LS additive for the rear. MS-10111
The rear takes something like 3 qts. The mopar product is like $25 a qt. You might consider something like this instead plus it comes with the LS additive. Half the price and widely used here.
Bmags
Minneapolis
2019 classic
This is what I put in my truck and my brothers. 2019 Ram Classic with factory Anti-Spin.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
It's the only half ton truck I ever saw spec'ing a 140 rear gear oil.
IDK if it's wishful thinking (a heavy duty wannabe) or they choose a chintzy axle set.
Hell, my heavy duty AAM with 11.5" dia. ring gear (! bigger than Ford Super Duty) calls for 75W-85 or 75W-90.
IDK, maybe the teeth are so big the load stress is low.
TC
Central TX
^^^ because of this I chose to run Amsoil 75-110. 3.21 rear end seems to like it. No towing.
